Measuring rf power around 300 MHz
Discussion in 'General Electronics Chat' started by mj3, Apr 19, 2016.
  1. mj3
    Apr 19, 2016
    Hi all,
    I'm trying to measure the power of an rf signal that frequency ramps over 200-400 MHz. My signal strength as measured on a spectrum analyser is around 0 dBm (into 50 Ohms) post-amplification (expects 50 Ohm load), but I'd like to know the total power in this band without requiring the analyser. Ideally I'd be able to measure Vrms or an associated quantity.
    Naively I considered rectifying the signal and charging a capacitor, but given the high frequency and (relatively) low amplitude of the signal I'm not sure this would work. Is there any "obvious" solution to this besides purchasing test equipment?
    Cheers
  2. Papabravo
    Feb 24, 2006
    10,340
    1,850
  3. Kermit2
    Feb 5, 2010
    3,850
    965
    If you can measure then get rms value with either a scope or a high impedance volt meter you will get a very close approximation of power levels
    Most of the error between theory and practice will be due to inefficiency of antenna matching. High SWR is a real Watt killer.
  4. mj3
    Apr 19, 2016
    Unfortunately I don't have a scope with high enough bandwidth to directly see the rf, which is why I'd like to convert it to a power measurement. I'll check out the Wattmeter, but would something like the AD8361 or MAX2014 be a cheap solution?
  5. MikeLogix
    Mar 1, 2016
    I don't think a Bird watt meter can measure the small amplitude signal (0 dBm) as stated by mj3. The Bird meter requires at least 100mW.
  6. dannyf
    Sep 13, 2015
    2,196
    417
    Try logarithmic amplifiers. Analog has a few of them. 8307 for example.
