Evening gents,
We are trying to measure the resistance, inductance and back emf constant for our PMDC motor.
To measure the resistance we plan on simply placing an ohm meter across the terminals of the motor and recording the resistance value.
To measure the inductance are either going to,
a) Use an inductance meter and simply measure it across the terminals of the motor, or
b) Excite the motor with a certain voltage (either a step input or periodic square wave) while locking the shaft of the motor in place(thus the back EMF is fixed to 0V) and by measuring the time for the exponential rise and/or decay of the current waveform on an oscilloscope, determine L via the time constant.
To determine the back EMF constant K, we were planning on exciting the motor with a 12V lead acid battery and a current limiting carbon disk resistor. Once the motor reaches a steady state speed, we will use a handheld tachometer turning with the shaft of the motor to measure the speed of the motor. Knowing the speed of the motor, the voltage at the terminals of the motor and the current flowing into the motor we can back solve for the back emf.
Using the ratio of the back emf with the speed of the motor (in rad/s) we will determine the back emf constant K.
Does this seem like a reasonable and valid way to determine the parameters of our PMDC motor?
Thanks again!
Thanks again!
