Yes, if the transistor isn't driven hard enough, it will be in active mode.By saying forward biased you mean that when the current starts flowing from the collector to emiter?
I wrote it that way because the junction was forward biased and I was looking at it from the perspective that the transistor was saturated; that lets you see very clearly that Vled+V3=5V. Your equation better illustrates the fact that the quantities you mentioned are in parallel.If BC has a voltage too, looking at a circuit i would say that V1=Vbc + Vled +V3, because Vbc seems to be in series with Vled and V3
Active mode you mean that the the the switch will be "off", i mean the current will not flow through collector and emmiter?Yes, if the transistor isn't driven hard enough, it will be in active mode.
No. That would be "cutoff". In active mode, the transistor is on, but not driven so hard that it saturates.Active mode you mean that the the the switch will be "off", i mean the current will not flow through collector and emmiter?
If you apply KVL to that loop, you get V1 + Vbc + V3 + Vled = 0. You can use arthmetic to arrange them any way you want. Using this equation, you can write V1+Vbc = -V3 - Vled. If you substitute numbers for the voltage drops, it will be clearer. We know that V1=4.3V and Vbc=0.7V, so 5V is across the LED and resistor.I have circled the places that i understand to be parralel.. I cant grap why V1+Vbc=V3 +Vled. I dont understand why we have to sum V1 and Vbc. Those 2 votlages doesnt seem like connected in series..
My mistake; too much fiddling with tex and I didn't proofread my post after posting. I corrected the equation.Is this the same circuit you showed me?
Why in your equation there is Vdcb on both sides o
If you start from the 5V supply and go counter clockwise starting with R1, you get (-4.3)+(-0.7)+3.0+2.0=0.But if i add all those 4 voltages according to KVL there is no way i will get 0 .
Ideally, when the transistor is saturated. When biased in the active region, the C-B junction would be reverse biased.Vbe is equal to Vbc when transistor is on yeah?
Pick a convention and use it. I considered voltage drops in the direction of travel around the loop to be positive and I'm traveling against negative. Was that not clear from post #52? I meant for it to be...How do i know which of them will be positive and wich one will be negative?
The whole point of a current source is that it delivers a constant current regardless of load. To do that, the source voltage has to have sufficient head room.I deal with several types of LEDs that range in color and in power. That means i cant use a constant current supply unless i make it adjustable.
Hello,The whole point of a current source is that it delivers a constant current regardless of load. To do that, the source voltage has to have sufficient head room.
If you wanted the circuit I posted to work with any LED, all you have to do is use a higher supply voltage. I breadboarded a PNP version of the current source and used it to test some white LEDs I had wired to work with a 6V battery. I increased the supply voltage to 9V and was able to "test" them; series 220 ohm resistor and all...
You're doing too much work. Forward voltage for modern LEDs is typically stated at 20mA. If you're testing at some other current, your forward voltage will not match manufacturer specs.
by Aaron Carman
by Jake Hertz
by Aaron Carman
by Jake Hertz
