Measuring gate capacitance of any MOSFET: Basic
Willen
Joined Nov 13, 2015
333
Once I bought IRF840 which was 2.5 times expensive than IRFz44. And its manufacture is unknown like it's marked as "IRF840 Y64K DK". IRF840 is expensive because it's very faster like 10MHz or less.
But seeing its unusual marking, I suspect that it might be a counterfeit part (maybe have slower chip inside instead of real chip of IRF840) to earn 2.5 times more.
I have one genuine IRF830 (almost same feature as IRF840) made by ST semiconductor. So to test the genuineness of the mosfet I bought with unknown marking, I want to check its gate capacitance (I cannot apply the mosfet in the device because I have not made the device, just planning) and want to compare with genuine IRF830 fast MOSFET and with IRFz44 slower too.
Can I check its gate capacitance by using a capacitance meter to Gate and Source pin simple as measuring any discrete capacitor? (maybe asking silly but I want to know about the unknown IRF840, I bought)
Papabravo
Joined Feb 24, 2006
21,158
I don't think that will yield the result you are looking for. Most Z5U capacitors have a pretty wide tolerance (+20%, -80%) unless they are graded for tighter tolerance. With the gate of a MOSFET the capacitance is a dynamic thing, it actually changes in operation. The best insurance is to buy from a reliable supplier. If you are uncertain about the quality, just return them and ask for a refund. Refusing to take them back would be a pretty good indication.
Willen
Joined Nov 13, 2015
333
I bought from a small local shop, and they think me like a terrorist or criminal or their biggest enemy if I went there to returned back the purchased parts. There's just few shop of consumer electronics parts so they are safe even if the behave cruel to customers. I am 100 years back from advanced world, maybe, in the case of electronics. (Online shopping is out of my capacity and hobby parts are no-where.)
DickCappels
Joined Aug 21, 2008
10,153
Most likely the extra letters and numbers "Y64K DK" are there to indicate features or packaging options, the factory, and/or the date of manufacturer.
You can measure the input capacitance if you do so in accordance with the conditions specified on the datasheet.
For example on the Vishay datasheet (www.vishay.com/docs/91070/91070.pdf) the conditions given are:
VGS = 0 V,
VDS = 25 V,
f = 1.0 MHz, see fig. 5
Willen
Joined Nov 13, 2015
333
Maybe it's more complicated because of my knowledge limit and equipment limit. For simple comparison, I will just measure the GS capacitance of genuine IRF830 and unknown IRF840 and IRFz44, lets see if I can get some clue or not. :)
34,281
Certainly you can compare capacitances, no matter how you measure them, to determine if there is a significant difference (say >20%).
If you measure both the same way, then it should be a valid comparison.
Papabravo
Joined Feb 24, 2006
21,158
I would caution that low cost meters might have the capability of damaging the gate oxide. If you have no other way to go then that's what you are left with.
Willen
Joined Nov 13, 2015
333
Did you mean the if I connected the Gate and Source pins to the capacitor testing shockets (two pins too) which measures capacitance migh generate high spikes voltage and might damage the Gate of IRF840?
Really I have a $5 DMM and it has a 'Cx' range to measure capacitance from 2nF to 200uF and has a two hole as shocket for capacitor insertion.
#12
Joined Nov 30, 2010
18,224
The gate of most mosfets can survive 20 volts. The battery in most cheap meters is 9 volts. I don't understand why 9 volts is more than 20 volts for this measurement.
Willen
Joined Nov 13, 2015
333
For capacitance measurement? Amazing the testing the gate with 9V DMM damages the gate! Being worried! I have tested some 2N7000, BS170 small fets.
Joined Nov 30, 2010
18,224
I just told you a 9 volt battery can't destroy a 20 volt gate, so now you're worried?
cmartinez
Joined Jan 17, 2007
8,218
Maybe Willen hasn't realized that the difference between a traditional bjt transistor and a mosfet is that the former is current-drive, while the latter is voltage-driven
Willen
Joined Nov 13, 2015
333
I tested them with cheap DMM (diode test) which is powered by 9V battery. I think the probe has just few volts.
What you think about static charges in the case of such damage? Are you sure the damage is due to DMM?
Willen
Joined Nov 13, 2015
333
The result about gate capacitance of my unknown IRF840 made me frustrate!
IRF830 genuine fast FET= 700pf
IRFz44 slow FET= 1.8nF
IRF840 unknown FET= 1.7nF
7N60 power FET= 1.5nF
the IRF840 seems counterfeit part! What the h___! IRF830 and IRF840 should have almost similar gate capacitance, should't it?
DickCappels
Joined Aug 21, 2008
10,153
(Some text removed)
Not necessarily. If you don't have the datasheet for the suspected part you can't really know -except in cases like the lot of 2N2222 NPN transistors I bough through the mail from a surplus dealer. Not only did they have the wrong pin-out, but they were PNP.
