I am going to be testing some electronics submerged in SALT water. The electronics draw about 8 Amps from a 12 Volt DC power supply. I am testing the seals to make sure water does not leak. What will happen if a seal fails and the salt water reaches the electronic board? Will the salt water create a short and trip out the power supply? OR Will the water carry current and zapppp me if I put my hand in it?
Can I measure and monitor the conductivity of the water? If a seal fails and the salt water reaches device board will the conductivity go up? Any ideas or suggestions to make this safe or should I even worry about it?
