measuring dc voltage in a unique way!
Discussion in 'Embedded Systems and Microcontrollers' started by poison3000, Oct 3, 2010.
  1. poison3000
    Oct 3, 2010
    22
    hello people ...
    u probably saw and used a Digital voltmeter (or multimeter ) .. and when u choose the a node to measure its voltage u can read it clearly on small LCD screen ...
    well , is it possible to have a circuit where some sort of a chip that u connect it across any component on the circuit ( say a resistor ) and that chip will start streaming bits that is linear to the dc voltage across that component ?
    my idea is to have two separate dc voltages outputted from two different chip , then a magical chip or circuit will read theses dc voltage output and intrepret it some binary value , then binary values taken to digital comparator and decides which dc voltage value is bigger in magnitude ...
    so , is there a way to build or find such chip ? what is it called ?
    please help :confused:
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    That task can be done by any number of microprocessors. They must be able to input at least two separate sources to the A to D converter. There must be some means to insure the measured voltages are within the limits of the device.
    After conversion, the larger voltage will have a larger numeric value.
    poison3000 likes this.
  3. poison3000
    Oct 3, 2010
    22
    hmmm ... can u , please , show me a reference to read ?
  4. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
  5. poison3000
    Oct 3, 2010
    22
    so basically i can deal with dc voltage as analog signal and use Analog-to-Digital Converter ? after all, dc voltage is continuous-time and continuous-amplitude , but with zero frequency .. right ?
  6. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    It can be, but a DC signal can vary with time at any frequency. The thing that makes it DC is that the signal voltage is always one polarity - either positive or negative. A signal becomes AC if it crosses the zero voltage line.
  7. poison3000
    Oct 3, 2010
    22
    thank u very much .. u saved my day !!!
