Ohk! I don't have these resistor values at the moment with me but tomorrow morning I will get them and try them!! What should I expect from this change ??Here's how the input amplifier should be if I understand correctly. I've recommended a couple of resistor changes to move the voltage at their centre point to 1.75V instead of 2.5V. This is because the LM358 isn't rail to rail, but 0-3.5V with a 5V supply.
Well you just mentioned above about the voltage change BUT on breadboard?? Should be the solution to the current problem??
Regards,
