Measuring Current using Current transformer
Discussion in 'Analog & Mixed-Signal Design' started by Qual, Sep 18, 2016.
  1. Qual
    Aug 5, 2016
    26
    Hi ,
    i was trying measure current using Current Transformer but i see spikes at the output of transformer and cant see proper waveform on oscilloscope.
    Attached is the waveform...
    Any suggestion.
    I want feed the voltage to Micro controller so that i can display same on LCD.
  2. DickCappels
    Aug 21, 2008
    2,774
    671
    That waveform is normal for some types of loads, especially capacitor input filters.
    What is the source (AC power line?) and load (input to a power supply or electronic appliance?) for the circuit you are measuring?
  3. Qual
    Aug 5, 2016
    26
    Source is AC power line and load right now using a rheostat..! ( 56 ohms)
  4. AlbertHall
    Jun 4, 2014
    2,275
    449
    The section at the top of the display seems to be showing a sine wave though:
  5. DickCappels
    Aug 21, 2008
    2,774
    671
    I am going to take a guess: You are not using a transformer that was designed to measure current or you do not have an adequate shunt. What kind of transformer are you using? What are you using for a shunt? (Shunt: The resistor across the primary that sets the scale)
  6. Qual
    Aug 5, 2016
    26
    i am using 56100C current transformer from Murata for measuring current.
  7. AlbertHall
    Jun 4, 2014
    2,275
    449
    You are way outside the frequency range of that transformer. From the datasheet:
    „ 20kHz-200kHz frequency range
    DickCappels likes this.
  8. Qual
    Aug 5, 2016
    26
    so i won't be able to measure current ?!! so is that transformer used is wrong ??
    any help pls...
  9. AlbertHall
    Jun 4, 2014
    2,275
    449
    You cannot use that transformer to measure current at 50Hz. It is intended for switched mode supplies and the like.
  10. MaxHeadRoom
    Jul 18, 2013
    10,851
    2,524
    What kind of current are you measuring, would a ACS712 work for you, although they are in circuit type rather than transformer, comes with isolation build in.
    The can be had for a couple of $'s on ebay with circuit, 5A, 20A and 30amp ranges.
    Max.
  11. Qual
    Aug 5, 2016
    26
    i want to measure the AC and DC current. Want to build my own circuit.... so this attempt
  12. MaxHeadRoom
    Jul 18, 2013
    10,851
    2,524
    The ACS712 measures AC & DC current and can be purchased as a bare IC, you still usually need some kind of interface.
    Max.
    Qual likes this.
