Measuring current On a dual slope integrator
Discussion in 'The Projects Forum' started by Siyom, Aug 13, 2012.
  1. Siyom
    Aug 9, 2012
    33
    How do you measure current using Dual slope integration,I know that this method uses time ratios to approximate voltages but in the case of measuring current,how do you modify the circuit?
    Or do you convert from voltage to current inside the MCU?if so how?
    I would upload a diagram of my circuit but that doesn't seem to work
