Measuring Current from 10pA to 100nA
Discussion in 'Programmer's Corner' started by farobin, Jul 29, 2012.
  1. farobin
    Jul 27, 2012
    Hello Everyone,
    I almost know nothing about circuit designing, apart from undergrad electronics. For the instrument I am designing
    for Radiation Dosimetry application, I have to be able to detect light
    with photo diode generating ~ 10pA to 100nA. Currently I am using Keithley
    Multimeter. But my system has to be handheld. Could you please give me a
    guideline how do I design a circuit to be able to detect this current range?
    Any help will be highly appreciated.
  2. bertus
    Administrator
    Apr 5, 2008
    15,799
    2,385
  3. kubeek
    Sep 20, 2005
    4,687
    805
    First, I think this should not be in Programmers corner, because it wont´t get too much attention here.
    Second, look at Dave´s uCurrent and see if you could adapt that schematic.
    http://www.eevblog.com/projects/ucurrent/
    Potato Pudding likes this.
  4. takao21203
    Distinguished Member
    Apr 28, 2012
    3,578
    463
    currents in this range are problematic to measure, because common EMI will induce such currents. Good shielding is essential.
    Radiation detector based on photodiodes are possible and have been built, however they have noise problem vs. sensitivity.
    Also these don't use small standard photodiodes, but special, large PIN diodes.
  5. MrChips
    Oct 2, 2009
    12,624
    3,451
    This should be my field of work but I would have to dig into the books to make it work.
    Usually we would use a PMT. Any particular reason for using a photodiode, apart from portability?
  6. farobin
    Jul 27, 2012
    Thanks everyone for suggestions.
    I would use PMT but HV required by PMT is a problem
    for portability, and in the wavelength range 750nm, PMT sensitivity
    falls rapidly. Infact for testing in the lab I used PMT, PD, CCD...but PD seems to be most user friendly for people and the cheapest.
    I contacted with TI, but they also suggested about forums.
    So kind of struggling to start with.
  7. ScottWang
    Aug 23, 2012
    4,925
    777
