measuring current and voltage
Discussion in 'General Electronics Chat' started by Dhwl325, Feb 8, 2007.
  1. Dhwl325
    Feb 8, 2007
    what is the difference between the two
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    May I suggest you read the relevant section in Volume I of the E-book on this site? There's a good explanation in it.
  3. RAH1379
    Dec 13, 2005
    69
    voltage is pressure and current is flow of electrons
  4. m4yh3m
    Apr 28, 2004
    186
    42
    The unit of electric charge, the coulomb, is defined in terms of the ampere: one coulomb is the amount of electric charge (formerly quantity of electricity) carried in a current of one ampere flowing for one second.[3] Current, then, is the rate at which charge flows through a wire or surface. One ampere of current (I) is equal to a flow of one coulomb of charge (Q) per second of time (t).
    Since a coulomb is approximately equal to 6.24150948×1018 elementary charges, one ampere is approximately equivalent to 6.24150948×1018 elementary charges, such as electrons, moving past a boundary in one second.
    (Ripped from Wiki)
  5. Dave
    Retired Moderator
    Nov 17, 2003
    6,960
    145
    6.24150948×1018 elementary charges would probably be more than all the electrons in the known universe! It should read 6.24150948×10^18 ;)
    Dave
    Edit: Ignore this nonsense about more than all the electrons in the known universe, the second bit still applies.
  6. Ron H
    Apr 14, 2005
    7,050
    657
    Errmmm, Dave... 10^18>>>>>>>1018.
  7. Dave
    Retired Moderator
    Nov 17, 2003
    6,960
    145
    Lol! My stupidity!! 6.24150948×1018 ~ 6354, which is very few electrons! I made the bludder interpretting the exponential notation as 6.24150948 e+1018.
    I will leave my boob up for all to see!
    Dave
  8. Ron H
    Apr 14, 2005
    7,050
    657
    Yeah, I figured that's what you did. :D
