Hi everyone. I am looking to measure 2 capacitors in parallel, one is 50pf and the other is 10pf. My circuit is attached, it uses a FET to switch between measuring the 50pf cap and the 50+10pf cap at the output. The capacitance meter measures the the caps in parallel (60pf) when the FET is on as well as off (measuring between the source (ground) of the FET and the output). The capacitance drops only about .4pf when the FET is off. The off resistance of the FET I measured to be about 1MOhm. Could it be that the off resistance is not high enough to cut the 10pf cap out of the circuit? Thank you.
