measurement
Discussion in 'General Electronics Chat' started by Robert123, Mar 21, 2010.
  1. Robert123
    Feb 12, 2010
    29
    measurement
  2. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    One easy way to measure current is to use a fixed resistance in series with the load, and measure the voltage across the fixed-value resistor.
    Ohm's Law says:
    E=IxR, or Voltage = Current time Resistance.
    Similarily,
    I=E/R, or Current = Voltage/Resistance.
    So if you have a resistor that measures exactly 1 Ohm, you can read the current flowing through the resistor by measuring the voltage drop across the resistor. In the case of a 1 Ohm resistor, 1V drop = 1A current.
    You can scale the resistance down if desired. If you use a 0.1 Ohm resistor, then a 1 Volt drop = 10 Amperes current through the resistor.
    PackratKing likes this.
  3. Von
    Oct 29, 2008
    65
    A current transformer is another alternative.
    It is a ring device and requires that the conductor pass throught the center.
    No voltage drop or other issues with inserting a device in series.
  4. Mike33
    Feb 4, 2005
    349
    25
