Measurement of Leakage reactance using resonant??
Discussion in 'General Electronics Chat' started by micktosin, May 16, 2014.
  1. micktosin
    Mar 20, 2012
    19
    Please how can I measure leakage reactance of a transformer using resoance? With C-=1.4uF, Leakage inductance= 20uH, magnetizing inductance=100uH, Switching frequency 30kHz, Turn ratio 9:3.
    P.s I have been trying to research on it, but no luck.
  2. crutschow
    Mar 14, 2008
    13,523
    3,391
    If you short the transformer secondary, than any remaining reactance is due to the leakage inductance, stray winding capacitance, and the primary and secondary winding resistance. So if you determine the primary resonant frequency with the output shorted, you should be able to calculate the leakage inductance from that. This may help.
  3. studiot
    Nov 9, 2007
    5,005
    515
    crutschow is correct.
    Here is the measurement procedure. You need three meters, current, voltage and power.
    Refer to the attachment.
    Short one winding and apply a low voltage to the other, increasing it until the rated current in that winding is achieved.
    At this point the equivalent circuit is as shown and the effective resistance, power angle, and leakage reactance can be calculated from the readings.
