measurement of alternating current
Discussion in 'General Electronics Chat' started by munna007, Aug 5, 2008.
  1. munna007
    Thread Starter Active Member
    Jul 23, 2008
    51
    hello friends....i have a digital multimeter ....there is only option of measurement of direct current,but not for alternating current....
    can wemeasure alternating current by connecting this multimeter in series with range of direct current on multimeter....????
    or i hav listened clamp meter is used for this purpose....anybdy hav idea of clampmeter????:)
  2. CVMichael
    Aug 3, 2007
    416
    17
    I don't get your second line, but can't you just put a diode in series with the digital multimeter ?
  3. Wendy
    Mar 24, 2008
    20,772
    2,540
    AC is an RMS value, a diode bridge probably wouldn't do it. Meters are pretty cheap though, wouldn't it be easier to buy a DVM with an AC Ampmeter?
    A clamp meter will measure AC current, and has a lot of desirable characteristics. The big one is not having to break the circuit to take the measurement, which can be dangerous with high voltage circuits. You have to have a SINGLE wire of the circuit available however to use one. My big use in the past is to identify dead heaters in a bank, this is where they are really useful.
    Do you have a clamp meter, or are you thinking of getting one? The new DVM is a lot cheaper, and probably more available.
  4. munna007
    Jul 23, 2008
    51
    i mean i want to measure alternating current with digital multimeter on dc current range .....can we do it????
  5. munna007
    Jul 23, 2008
    51
    thanks a lot sir......
    if we do what i hav asked in question what will happen....whther dm will burn out or not????
  6. Wendy
    Mar 24, 2008
    20,772
    2,540
    As long as the current is DC, which a bridge will convert it to, it will not burn out. The readings won't be very close though.
