Hi everyone !
I have a circuit which only has two 1ohm resistors in series. And I use a dc power supply to apply a 1mv voltage on them.
and then I measure the voltages across the two resistors using the 2 leads of an oscilloscope. The results displayed in the screen is noisy.
(with the lead connected to the hv side and the black clip connect to the lv side )
And then I apply 50mv to the circuit. Voltage measured Channel 1 is about 30mv and the voltage from channel 2 is quite low(only around 400uV and is not stable). However when I inverse the connection of the lead of the channel 2 (lead---lv, clip----hv),the voltage apperas on the screen are about 25mv of CH1 and -25mV of CH2.....
I cannot figure out what happen. I think the way i do the measurement is wrong. and maybe I need to amplify the samll dc voltage ?
Please give me some advices please ! Thanks !
