Measure small time periods with 1ns resolution
masteropie
Joined May 17, 2008
26
I am looking to measure around 1us time periods with a pic down to 1ns resolutions for experimenting with lasers and ultrasonics. I have an idea, seams fairly simple.
Sample at 1ghz and use some sort of serial to parallel shift register to change the data into 16bit so it can be entered into 16bit ram every 16 clock cycles. Then the pic can take its time and measure the string of 1s in ram. For example: 00000011111111000000000 would be 8 nanoseconds.
It seams like it world work to me. Just i have no idea know how to make 1gb/s serial into 16bit parallel. Everything available seams like it is way to slow, I must be looking at the wrong thing.
scubasteve_911
Joined Dec 27, 2007
1,203
I found some 9-bit serial-parallel converters that can easily run that fast.
MC100EP142
OnSemi and Micrel make some pretty fast ECL logic.
Your ram idea seems a bit complex, you would know this if you ever interfaced to a RAM chip. You need a controller to run fast ram, because it needs refreshing, etc.
Typically, they use very fast counters with triggers to measure quick events. So, you'd run a counter at over 1GHz and trigger it when you are timing something, then shut it off, then figure out how many pulses it took knowing your frequency, which gives you the time.
Steve
masteropie
Joined May 17, 2008
26
Yes, a counter does sound much easier. However i can't find any 20bit+ counters that can operate at 1ghz. Would a 9 bit shift register then a 9 bit counter be used?
hgmjr
Joined Jan 28, 2005
9,027
Can you provide us with an explanation of what you are trying to measure that needs to have 1E-9 seconds?
hgmjr
SgtWookie
Joined Jul 17, 2007
22,230
Our OP apparently wants to get close to 1 meter of resolution using a laser (ballpark).
Using such frequencies with ultrasonics would be somewhat pointless, as the speed of sound is so slow in comparision that even a large array of counters or shift registers would've shifted out by the time the return came back.
hgmjr
Joined Jan 28, 2005
9,027
Yep. The use of ultrasonics to obtain nanosecond resolution would be like using a yardstick to measure the width of a human hair.
hgmjr
masteropie
Joined May 17, 2008
26
I would like to measure other things also. Possibly a ultrasonic flow meter also which would require 5ns resolution for 1cm/s with a transducer spacing of 5cm. Just would like this as a general tool.
That is why i was thinking ram since a simple chip could store 16 million counts. 24bits of storage should also be able to hold 16 million counts. It guess it is more complicated then it seams due to the speed.
beenthere
Joined Apr 20, 2004
15,819
One centimeter per second flow measurement with 5 nanoseconds resolution? Sounds a bit like measuring miles with a micrometer.
scubasteve_911
Joined Dec 27, 2007
1,203
You can cascade the 9bit counter that I mentioned. I was actually thinking about doing a laser TOF system with this stuff before, but decided against it. I wanted better resolution and it wasn't possible with what I could get my hands on.
Steve
