Measure current and voltage of battery being charged using PIC
Discussion in 'Embedded Systems and Microcontrollers' started by goliathpk, Apr 29, 2009.
  1. goliathpk
    Apr 29, 2009
    Hello everyone
  2. lightingman
    Apr 19, 2007
    374
    22
    Hello.
    You would need to give more details:-
    What are you using to measure the current? Resistor, hall effect device or what....
    The hall effect current transformers are very acurate and can be read directly by a PIC's analog inputs.
    If your battery voltage is greater than 5 volt, you will need to use a couple of resistors to divide this voltage, as the PIC can only read 0 to 5 volts.
    So basicaly, read the voltage.
    Read the current.
    And and wait for the correct voltage/current condition, then stop the charging.
    If you wish, you could also add an LCD and display the charging condition and status.
    Good luck.
    Daniel.
  3. russ_hensel
    Distinguished Member
    Jan 11, 2009
    820
    47
    I am working on building one now. Use op amp to condition the voltage input from the battery into a range for the adc converter on the pic. I use a differential amp with a gain of 1/4.
    On the low side of the battery insert a sense resistor, say 1 ohm for currents up to 1 amp. I use an amp with a gain of say 4 feed it to another adc on the pic.
