measure average current consumption
Discussion in 'General Electronics Chat' started by bug13, Jun 21, 2013.
  1. bug13
    Feb 13, 2012
    1,213
    38
    Hi guys
    How do I measure the average current consumption of a servo motor, so that I can calculate how many cycle my circuit can run for a known battery.
    After receiving a signal from a user, the servo will go to position A, then wait for 4 seconds, then go back to the original position B.
    How do I work out the average current consumption?
  2. WBahn
    Mar 31, 2012
    18,085
    4,917
    Measure the current over one or more cycles and average it. How you do that depends on what measurement capabilities you have access to, which of course we can't even begin to guess at.
    bug13 likes this.
  3. crutschow
    Mar 14, 2008
    13,475
    3,362
    You can integrate the current with either a A/D converter and a microprocessor or an analog integrator with a long time-constant.
    If the servo current is relatively constant when it's ON then you just multiply that current by the duty cycle (ratio of the ON to OFF time).
    bug13 likes this.
  4. KMoffett
    Dec 19, 2007
    2,584
    234
    I would think that in one position or the other, if the servo is always powered, the current would be pretty constant. The only variation would be during the brief period when it's moving from one position to the other. How often is it moved from A to B? Just measure the hold current and the move current. Calculate you average from that. If the difference between hold and move currents isn't great and the time between moves is long, then just consider the hold current.
    Ken
    bug13 likes this.
  5. THE_RB
    Feb 11, 2008
    5,435
    1,305
    I use a 'scope and a series resistor on the power wire. You can move the servo through the required pattern, and the scope shows current at all points in time. Then a few calcs will give you a pretty good idea.
    A digital 'scope or PC based 'scope is best as it can record slowly and gives you time to analyse the current waveform.
    bug13 likes this.
