Meaning of BATTERY polarity
Discussion in 'General Electronics Chat' started by lefam, Dec 9, 2010.
  1. lefam
    Nov 30, 2010
    33
    Hi guys!
    I am pretty new to electronics. I am having some problems with my first circuits and I am now suspecting that maybe my understanding of battery polarity is wrong.
    So, my question is: in batteries (example 9V alkaline) the (+) terminal is +Vs, and the (-) terminal is GROUND?
    (+) terminal = +Vcc?
    (-) terminal = GROUND?
    I have been using (-) like +Vs and (+) like GROUND. Probably the cause of failure in my first circuits.
  2. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    Yes, you could consider the (+) terminal as +Vs and the (-) terminal as the 0v reference point (ground), or the supply return.
    Circuits just plain don't work if you connect the power up backwards; and you may have destroyed the parts in your circuits. Polarized aluminum caps, polarized tantalum caps, Zener diodes, etc. just don't work the same way when you reverse the polarity of voltage across them.
    lefam likes this.
  3. lefam
    Nov 30, 2010
    33
    Thanks a lot
