mean value of a signal
Discussion in 'Homework Help' started by u-will-neva-no, May 9, 2011.
  1. u-will-neva-no
    Mar 22, 2011
    230
    Hello everyone, I have what appears to be a simple question, however i have a few questions regarding it..
    My first question(well more of a check whether im doing it correctly) is to work out the mean value of the waveform V(t)=Acos(Wt)
    Here is my solution:
    _ T
    V = 1/T ∫ Vdt where T= 2∏/W
    _ 2∏/W
    V = W/2∏ ∫ Acos(Wt)dt
    _ 2∏/W
    V = W/2∏ [AsinWT/W ]
    _ 2∏/W
    V = A /2∏ [sinWT ]
    _
    V = A /2∏ [sin2∏ -sin(0) ]
    _
    V = A /2∏
    Does the final answer seem correct? I only question this because squaring the above, does not give me the correct answer of :
    _
    V = A^2 /2
    Please tell me what I am doing wrong! Thanks :)
  2. u-will-neva-no
    Mar 22, 2011
    230
    hmmm...the values on the integral have moved...For line 1, T and 0 are the integral limits, line 2 has limits 2∏/W and 0 and lines 3-4 have boundary conditions 2∏/W and 0. Sorry about that.
  3. someonesdad
    Jul 7, 2009
    1,585
    141
    Here's a tip -- spend some time learning to use the LaTeX features of this site. They're pretty simple and make for easier-to-read equations. You're asking people for help, so make it easy for them to understand your question. I was willing to help, but because I can't read the equations easily, I just went to another post.
    u-will-neva-no likes this.
  4. ErnieM
    Apr 24, 2011
    7,435
    1,625
    = A /2∏ [0 - 0]
    = A /2∏ [0]
    = 0
  5. u-will-neva-no
    Mar 22, 2011
    230
    Thanks^^ @someonesdad, thankyou for the latex info, I really didnt realise how to do that. Im going to re-write the question again (even tho ErnieM helped with my issue) just to practice with it...
  6. u-will-neva-no
    Mar 22, 2011
    230
    {tex}\omega = 2\cdot\pi\cdot\f {/tex}. This is just a test, please ignore...
  7. u-will-neva-no
    Mar 22, 2011
    230
    \omega = 2\cdot\pi\cdot\f .
  8. bradstormer
    Member
    Aug 6, 2010
    65
    i think if you wanted a short cut, to get the mean of a sinusoidal waveform you can multiply its peak by 0.606
    handy if in a hurry, but only for sinusoidal waves
  9. ErnieM
    Apr 24, 2011
    7,435
    1,625
    You keep using that word.
    I do not think it means what you thing it means.
  10. bradstormer
    Member
    Aug 6, 2010
    65
    my bad its actually 0.637 to get the mean.
    What word am i confusing ErnieM? sinusoidal? if so i mean it in the context of a pure sine wave.
  11. ErnieM
    Apr 24, 2011
    7,435
    1,625
    If by "mean" you mean "average" then the average value for any sine wave may be determined by multiplying a constant times either the peak value, the RMS value, or any instantaneous value, as the constant is always...
    Zero.
    There is no average voltage in a sine wave. The average value is the DC value. u-will-neva-no just showed a proof of that.
    Also I believe .606 was a typo as you meant .707 which is the factor from peak value to RMS for a true sine wave.
    Also, there is no parking in the red zone. The red zone is for loading and unloading only. :D
  12. Jony130
    Feb 17, 2009
    3,990
    1,115
    Well if we talking about sin wave.
    For sure the average value for the whole period is equal 0.
    But we can talk about average value for the half of the period .
    Then the average value is equal
     V_{AVG} = \frac{2}{\pi} * Vp = 0.636619772 * Vp
    Where Vp - peak value
  13. bradstormer
    Member
    Aug 6, 2010
    65
    you can calculate a mean value, which is often, (maybe mistakenly granted) refered to as the average.
    to calculate the mean you can multiply the peak by 0.637 (because the mean value of a sine wave is 63.7% of the peak). it cannot be used for say on the output of an SCR.
    this site explains it a little better than i can i think!
    http://www.electrowavecorp.com/images_and_links/power_measurements.htm
    thats what i was trying to say Jony130,, i thought i was goin bonkers!
