I m supposed to design a dc to dc buck converter(SMPS)with following specifications .
input operating voltage range--18-30v
input voltage transient limit(converter survival)-44v for up to 1ms
output power range(resistive load)-75 -150W
allowed output voltage ripple(p-p,any load)-250mv
allowed input current ripple(p-p,ideal souce)-250ma
minimum efficiency(accross voltage,load)-80%
ambient temperature range= -20deg-40deg-
i m a begginner and need some guidance..this is the first designing project i m doing and hence HAVIN A LOT OF DOUBTS...which r as follows
Q:how do we calculate efficiency for a buck converter?
Qower ratings of resistive load is given..but what kind of load does it represent?dat means wt shud i use as a load,which can stand 12v and has low resistance??
Q:do we need an input filter in this project....?
Q:what shud be appropriate switching frequency for this buck converter without complicating the design and why?
Q:how do i select the mosfet type ...on what basis shud i choose?
plz guide me...smebdy..i need help...??
