MCU Null pointer
Discussion in 'General Electronics Chat' started by aamirali, Jun 19, 2012.
  1. aamirali
    Feb 2, 2012
    415
    Null pointer points to zero address, also in MCU zero address is special fuction register normally.. Don't they conflict with each other. If I define malloc function & MCU won't be able to allocate memory then malloc return null address,
    then what could be the problem.
  2. aamirali
    Feb 2, 2012
    415
    help abt dis..........
  3. kubeek
    Sep 20, 2005
    4,691
    806
    That is why you allways should check if ptr!=null after allocation. If you don´t do that you´re asking for trouble regardless of MCU or CPU you´re using.
