MCU analalog input sensitivity
Discussion in 'Embedded Systems and Microcontrollers' started by mah, Apr 27, 2015.
  1. mah
    Thread Starter Active Member
    Mar 15, 2010
    276
    i have analog signal ranging from 0 to 10 V and i want to input it to the microcontroller. but i think that the maximum input to MCU is 5 v so how to solve this?
  2. bertus
    Administrator
    Apr 5, 2008
    15,806
    2,389
    Use a voltage divider.
    Bertus
  3. mah
    Mar 15, 2010
    276
    if i used a voltage divider to convert it to 0-5v, will it sense the 0.1 volt which means 0.2 before divider ?.
  4. bertus
    Administrator
    Apr 5, 2008
    15,806
    2,389
    Yes, with a voltage divider of 2:1 the 10 volts becomes 5 volts and 0.2 volts becomes 0.1 volts.
    Bertus
  5. mah
    Mar 15, 2010
    276
    what is the least value that could be read? could it read signal in mv i mean the values after 0 directly?
  6. bertus
    Administrator
    Apr 5, 2008
    15,806
    2,389
    The lowest measurable voltage will depend on the number of bits in the ADC.
    When having a full range of 5 Volts a 8 bit ADC will give you 5/256 = 19.53 mV
    A 10 bits ADC will give you 5/1024 = 4.883 mV
    A 12 bits ADC will give you 5/4096 = 1.221 mV.
    Bertus
  7. MikeML
    Oct 2, 2009
    5,451
    1,066
    Depends on the # of bits in the ADC: 8bits=256 steps, 10bits = 1024 steps, 12 bits = 4096 steps.
    If the ADC reference voltage is 5V (also full scale input), then 5/256, 5/1024, 5/4096 is the smallest step that the ADC can resolve.
  8. nsaspook
    Aug 27, 2009
    3,018
    2,383
    If you use a voltage divider be sure to meet the impedance spec for the ADC. If you're just reading a slowly changing signal or DC adding a low value filter cap on the pin to ground ref will do the trick but to read a fast changing signal accurately you should buffer the signal.
