MCP6021/2/3/4 Spice Model
Discussion in 'General Electronics Chat' started by tindel, Nov 28, 2015.
  1. tindel
    Thread Starter Active Member
    Sep 16, 2012
    576
    196
  2. tindel
    Sep 16, 2012
    576
    196
    Well, I got it to work by lowering the negative input resistors by an order of magnitude. It doesn't seem to matter in real life. Maybe the sim thinks the input capacitance is higher than it is in actuality?
  3. MikeML
    Oct 2, 2009
    5,451
    1,066
    I cant get it do the .dc solution. It is complaining about the size of some internal transistors in the model.
    tindel likes this.
  4. MikeML
    Oct 2, 2009
    5,451
    1,066
    What do you mean by the "negative input resistors"?
  5. tindel
    Sep 16, 2012
    576
    196
    Sorry I wasn't very clear... the resistors attached to the inverting input.
    I think it's upset because it should oscillate with the large value resistors... but I'm not seeing that in real life. Hmmm.
  6. tindel
    Sep 16, 2012
    576
    196
    That's what I was seeing too.. thanks for the second set of eyes.
  7. Bordodynov
    May 20, 2015
    670
    194
    You are using LTspice? If so, then I can probably help you. I make modifications to improve the convergence of the models. Load your 'asc' file. Then I'll take care of the problem on Monday. Messages (warning) about the size of the transistors are ignored.
  8. tindel
    Sep 16, 2012
    576
    196
    @Bordodynov - Knock yourself out if you'd like. I ended up using a similar part out of the LT opamp database. Based on the opamp models I've seen in the past, this is a classic case of someone (postdoc maybe?) over analyzing something to the point that it's useless. Gotta love microchip... everything works - kind of... including the chips!
  9. Bordodynov
    May 20, 2015
    670
    194
    Not so simple. I modeled the generator current operational amplifier MOS transistor and the source of the reference voltage. I do it for the laser diode. I made a pulsed laser current control. I was looking for that cheapest operational amplifier. For this indicator, I won an operational amplifier from Microchip. But this amp turned excessive current spikes. Amplifier had no other firm of current emissions (at least in the simulation).
