Testing a DAC MCP4822 (data sheet here) I noticed it hot to touch with 2V at the A output. Last settings transmitted through the SPI interface were to have just 0,5V at VoutA.
Additional consumption current with that IC in-circuit was as of about 50 mA. No surprise it was hot.
After discarding a short, I found that:
From all the above, what could be the reason for the damage? Maybe the abrupt changes with a big charged cap at the output and no resistor to drain it?
I expect to learn something from all this. Comments are welcome.
Successful design, let me tell you...
- VoutA - pin 1 (and VoutB - pin 3 for the case) had no load resistors.
- Both outputs had 4u7F tantalium caps as filters.
- The software had an error that never latched VoutA when values were being progressively decreased. In other words, after going high, VoutA never came down.
- The test I designed, involved cyclic alternative reset of both outputs, starting with very low values. There, VoutA was effectively (and abruptly) updated.
