MC60 Control board
Discussion in 'The Projects Forum' started by ohmslaw08, Jul 20, 2013.
  1. ohmslaw08
    Jul 20, 2013
    9
    My treadmill has MC 60 control board, I found that the resistor R42 is open. I am having difficulty reading the color coding of the resistor to determine the ohmic Ω value. Can any one tell me how many ohms is R42 or at least tell me what are the exact color of the first 3 bands. Thanks.Ω
  2. absf
    Dec 29, 2010
    1,493
    374
    Is R42 parallel with R40 and R40 is 36.5K?
    Allen
  3. ohmslaw08
    Jul 20, 2013
    9
    Thanks, I will try to insert that resistor value. Will you be able to identify the band colors though?
  4. GopherT
    Nov 23, 2012
    6,326
    4,054
    There are many PCB versions of this generic control board. Each has the resistors numbered differently.
    This one doesn't even have a resistor where R42 is labelled on the board.
    http://www.ebay.com/itm/Treadmill-m...0?pt=US_Cardio_Treadmills&hash=item19d862fd4e
    My suggestion is to look at the other listings on eBay when you search m60 controller. Hopefully you can find a board with the same layout and read the stripes on R42. Click each image to see if a high res version is linked to it.
    Good luck.
  5. ohmslaw08
    Jul 20, 2013
    9
    @GopherT, tnx for the suggestion. I should be able to find the enlarged photo of the resistor in ebay or elsewhere. All I need is the color codes.
  6. ohmslaw08
    Jul 20, 2013
    9
    I can try solder 36.5K resistor in the card to see if it will work. But the only thing worries me to do this is if value is too low than what it should be, the adverse effect on the entire PCB?
  7. absf
    Dec 29, 2010
    1,493
    374
    I think you mistaken my post. I have not gave you the value of R42 yet. I just asked you if it is parallel with resistor R40. If it is, then the value of R42 that I have is probably correct.
    R40 = 36.5K (orange, blue, green, red )
    R42 = 5.4K (green, yellow, black, brown)
    Here's the schematics attached
    Allen
      File size:
      274.7 KB
      156
  8. GopherT
    Nov 23, 2012
    6,326
    4,054
    What an odd schematic to use the odd size like 36.5k in parallel with another odd size 5.4k to yield the equivalent of a very standard 4.7k ohms.
  9. ohmslaw08
    Jul 20, 2013
    9
    If R40 & R42 are both Kilo ohms value, then the 3rd band which is the multiplier should be red? None of those valuse doesnt agree with the rule.
  10. GopherT
    Nov 23, 2012
    6,326
    4,054
    Higher precision resistors have three value bands and a 4th being the multiplier (5th band is tolerance).
  11. ohmslaw08
    Jul 20, 2013
    9
    I am electronically novice. Even if 4th band is the multiplier, the posted colors does not come up with the numeric value of 36.5k nor the 3.6k for the other set of colors.
  12. absf
    Dec 29, 2010
    1,493
    374
  13. GopherT
    Nov 23, 2012
    6,326
    4,054
    Comes out as
    Orange is 3
    Blue is 6
    Green is 5
    Red gives two zeros
    3 6 5 0 0 (36.5k)
    Green is 5
    Yellow is 4
    Black is 0
    Brown gives ONE more zero
    5400
  14. ohmslaw08
    Jul 20, 2013
    9
    Im electronically novice. Even if the 4th band is the multiplier, still the posted colors does not enterprit the correct numeroc value of 36.5K nor the the other set of colors.
  15. djsfantasi
    Apr 11, 2010
    2,911
    881
    Check out this chart and GopherT's post...
