MC14538B as astable ?
Discussion in 'Digital Circuit Design' started by inwo, Aug 9, 2016.
  1. inwo
    Nov 7, 2013
    2,435
    315
    I would like to use 1/2 for retrig. monostable and 1/2 for astable if its possible.
    Or find a dual timer that does both. ~12v
    555/556 type isn't a good choice for retriggering. IMO
  2. hp1729
    Nov 23, 2015
    2,083
    232
    I don't have an example made up but if you put a power on reset circuit on the reset line and tied the Q0not output to hi trigger input it should go astable but only be in the reset state for about 50 ns. On power on it comes up reset, triggering it. When the timing times out Q-not goes high again, clocking it ...I don't think I ever tried it since I don't have it in a drawing, but in theory it should work.
    inwo likes this.
  3. AnalogKid
    Distinguished Member
    Aug 1, 2013
    4,679
    1,295
    A CD40106 or CD4093 can do both functions in one chip.
    Does the retriggerable gate the oscillator?
    What is the freq range of the oscillator?
    ak
  4. GopherT
    Nov 23, 2012
    6,300
    4,020
    What is your goal and what are the constraints. Any reason for limiting to a single chip?
  5. jpanhalt
    Jan 18, 2008
    5,699
    909
    If you are looking for how to connect the MC14538 as an astable, this might help (you may want the whole application note, see link below):
    Source: Fairchild AN366 (available here: http://www.scarpaz.com/Documents/AN-366.pdf)
    As just an FYI, MC1xxxx numbers are usually equivalent to NNxxxx . That is, to find circuits for MC14538, try searching on CD4538 or any other chip with just 4538 in its ID.
    John
    GopherT likes this.
  6. Alec_t
    Sep 17, 2013
    5,957
    1,133
    Here's a way you can use 1/2 a CD4538 as an astable :-
    inwo likes this.
  7. GopherT
    Nov 23, 2012
    6,300
    4,020
    Nice find. Very interesting things in there. I have been looking for the answer to @inwo 's question for a long time and I assumed it couldn't be done.
  8. AnalogKid
    Aug 1, 2013
    4,679
    1,295
    Another option is the dual comparator LM393. Both functions in only 8 pins, 2 V to 36 V power supply range.
    ak
    inwo and GopherT like this.
  9. inwo
    Nov 7, 2013
    2,435
    315
    I'll try that.
  10. inwo
    Nov 7, 2013
    2,435
    315
    An exercise in kiss.
    Circuit from my other thread works with a retriggerable monostable into an astable 555.
    Making sure I'm not missing a simpler way to do it.
    For those who missed it.
    Project has a signal in from <10 to 500hz.
    Output needs to follow input to ~350hz.
    This is where I'm at so far using TTL.
    Just got in some more parts.
    Over 350hz output = 350 retriggermono123a.png hz.
  11. jpanhalt
    Jan 18, 2008
    5,699
    909
    Have you changed your mind? KISS
    John
  12. inwo
    Nov 7, 2013
    2,435
    315
    I have 14538 now.
    Quite sure that 1/2 will work as my retrig-mono.
    If the other 1/2 can be a gated astable, I'm in business. One chip solution.........
    If not I'll go back to adding a 555.
  13. inwo
    Nov 7, 2013
    2,435
    315
    Is there an easy way to retrigger 555 (1/2-556)without more active components?
    Heck, maybe I can do the whole thing with one 555.
    I'm open to suggestions.
  14. inwo
    Nov 7, 2013
    2,435
    315
    14538 same?
    Here is the retrig- mc14538.gif mono 1/2.
  15. GopherT
    Nov 23, 2012
    6,300
    4,020
    Yes, the MC14538 is the same as CD4538 or HEF4538.
    inwo likes this.
  16. Alec_t
    Sep 17, 2013
    5,957
    1,133
    Use appropriate R and C values; the ones in the sim are merely for proof-of-concept.
    inwo likes this.
  17. jpanhalt
    Jan 18, 2008
    5,699
    909
    Please start by reading post #5.
    John
  18. inwo
    Nov 7, 2013
    2,435
    315
    I didn't check the link, as I was aware of that method which requires more gates and both halves.
    I'll check it out.
  19. inwo
    Nov 7, 2013
    2,435
    315
    Would you be willing to add a monostable half in the sim? :)
    Oh wait, I have to see if I can gate your astable circuit. :(
  20. inwo
    Nov 7, 2013
    2,435
    315
