Discussion in 'General Electronics Chat' started by SteveYTI, Sep 27, 2004.
  1. SteveYTI
    Feb 9, 2004
    I am looking for a data sheet for a motorola chip from long ago
    Have looked all over the net was hoping someone would know of a place to find this type of information... thanks!
  2. mozikluv
    Jan 22, 2004
    hi steve,
    your best bet of getting the datasheet of that old chip is still with motorola or at onsemiconductor. i once had that same problem, you just have to be persistent with their people and eventually have you what you want. its either you get the datasheet or if that is a phase out item they will give you the substitute which is usually the improved version. :)
  3. Martin miller
    Oct 1, 2004
    Here I found complete MC1405L datasheet. It's a A/D converter in DIP16 package (MC1505L is the same chip with extended -55 to 125 C operational temperature range).
