MC-60 Motor Control board problems
Discussion in 'The Projects Forum' started by Bobkat, Dec 19, 2012.
  1. Bobkat
    Dec 17, 2012
    7
    I have an mc-60 control board that does not start the motor or run the motor on my old treadmill.
    Choke is closed so I eliminated that, console pot works. Breaker is good. I have a spare motor and that will not work with the board either. I tested both motors and they will spin when I hook them to my 12v PS.
    spd ctrl led will light when the console pot is on. 12v led is always lit when ac is applied. I get 54vdc out of the motor spades on the board( a+ a-) if the wires are disconnected but no voltage reading if the motor is connected.
    What is a good plan of attack? I don't have an oscillator that I can use but I do have a good fluke meter to test with.I have been toying with electronics since the age of 14 and can solder pretty good, but unless it's an obvious thing I am lost.
    A new board is something like 83 bucks so I'm hoping I don't have to spring for that. Treadmill is 18 years old but the belt is good and I am hoping to keep it going.
  2. Dodgydave
    Jun 22, 2012
    5,154
    772
    You need a circuit diagram or another pcb to compare..
  3. Bobkat
    Dec 17, 2012
    7
  4. Bobkat
    Dec 17, 2012
    7
    Here is a pic of the board
  5. Dodgydave
    Jun 22, 2012
    5,154
    772
  6. Bobkat
    Dec 17, 2012
    7
    Thank you Dodgydave
    Label on it is looks like TLP3021 but I assume it's a MOC3021
    Is there a way to test out the optocoupler?
    Does anyone know if there are other components that commonly fail on these controller boards or that should be replaced while I am at it?
    I did see a couple separated resistors that I soldered back together. On further reading I find the factory cuts certain resistors depending on application. there is one called 6-8 mph that was in bad shape ( r37) I am not sure if that should be left disconnected.
    Edit: I jumped out the SCR LED and the motor works normally. I did find an optocoupler at a local store for 3.99 so I'll go get that. hopefully they'll have an LED also. I think it's .64 at digikey but the shipping charges make it more expensive.
  7. JoeJester
    Apr 26, 2005
    3,402
    1,221
    Did you look at the datasheet of the TLP3021 and the MOC321?
  8. Bobkat
    Dec 17, 2012
    7
    I got a NTE3048 which cross referenced to the TLP3021. I guess they are different from the moc3021. MOC3021 crosses to a different optoisolator .. now to figure out which is pin 1 on the nte as there is no dot there? The data sheet on the nte web site for that optoisolator shows a dot on it to locate the pin 1. Maybe I have to call them tomorrow to find out. Or would it be on the side with the stepped area?
    The old one on the right in the picture has a nice indentation marking pin 1
    DATA sheet on the new component:
    http://www.nteinc.com/specs/3000to3099/pdf/nte3048.pdf
      File size:
      274.4 KB
      51
  9. tubeguy
    Nov 3, 2012
    1,157
    197
    I looked at the photo before reading and thought as you did.. the stepped side.
    Why not checK for the LED as you would a diode if you have a meter handy?
  10. Bobkat
    Dec 17, 2012
    7
    Beveled edge is the indicator for this component for the side with #1 pin
  11. Bobkat
    Dec 17, 2012
    7
    Got it going, first time didn't go but I found I messed up the trace from pin 6 to D6. Made a wire out of the extra they gave with the led and jumped them below the board with that.
    Works normally now :) ty all for the help
