May I know the value of the burnt resistor?Thanks!!
Discussion in 'General Electronics Chat' started by wkyong, Jul 23, 2008.
  1. wkyong
    Thread Starter Active Member
    Apr 29, 2008
    33
  2. Externet
    Nov 29, 2005
    780
    58
    Not exactly. As a guess, it may be in the vicinity of 47 Ohms, and probably blew up because the power transistor is very shorted base to collector, and that happened either by over current in the secondary or the switching stopped in conduction state.
    Try to find another power supply to read its value and replace after fixing the cause.
  3. Ron H
    Apr 14, 2005
    7,050
    657
    The 240 ohm resistor will limit the current to less than 10mA. With 47 ohms, Vbe would be less than 0.5V, so the BD140 would never turn on.
    I would try a resistor in the range of 470 ohms to 1k.
