maximum wimax transmit power
Discussion in 'Computing and Networks' started by milos, Feb 10, 2008.
  1. milos
    May 6, 2007
    hi there,
    i was wondering what is the typical max downlink transmit power (from base station) of WiMAX?
    what is the maximum number of users that are usually supported in a cell of a WiMAX network?
    any comments on this metter would be very much appreciated.
    thank you.
    best ragards
    Milos
  2. nanovate
    Distinguished Member
    May 7, 2007
    665
    This depends on whether it is operating in an licensed or unlicensed band.
  3. AlexR
    Jan 16, 2008
    735
    54
    I'm no expert in the field but from what I can gather the WiMax standard supports 256 channels of which about 200 are available to end users.
    Base station power seems to be in the 5 to 50 Watt range.
  4. milos
    May 6, 2007
    Thank you all on the reply.
    i believe that if WiMAX is operating in the 2.5GHz frequency range that the maximum transmitted power is around +20 dBm?????
    AlexR, when you say 256 channels are you refering to the OFDM subcarreirs? If 200 channels are available to end users does it mean that maximum number of users is 200? or it depends how many subcarriers you allocate for each user?
    i appologize if the questions are a bit trivial but i am new in this filed and quite interested in WiMAX?
    Thank you again on your time.
    Regards
    Milos
  5. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    There are 16,000,000 hits on google for "wimax". Lots of information is available to you.
