Maximum Power Transfer
Discussion in 'General Electronics Chat' started by mlkcampion, Jun 26, 2007.
  1. mlkcampion
    Thread Starter Active Member
    Nov 16, 2006
    59
    Hey
    I was reading through my copy of Schuams Outlines (Electric Circuits)
    and i came across the theory of Maximum Power transfer, i have already
    looked at the threads on this topic however my question regards the
    equation used to describe the power absorb by the load.
    I have scanned the small section from Schuams Outline. (see attachment)
    I can't work out how you go from the first equation to the final one
    which i have underlined in orange, i understand that the part inside
    the square braces is the effeciency but still can't get to this result.
    Can someone explain?
    Cheers
  2. recca02
    Apr 2, 2007
    1,211
    one way to get to the expression RL=R
    wud be
    differentiating the PL expression(the simple one derived from power =sq(i).r) and equating to zero and u may even check with second derivative whether it implies a maxima or minima by finding if the value of second derivative is positive or negative.
    edit: right now i can only explain how to reach that expression (manipulation has been my specialty).
    multiply numerator and denominator by 4R.
    now manipulate as (RL+R)^2 -(RL+R)^2= 4RL.R
    rest shud be easy split the fraction in two parts and cancel (RL+R)^2 take out common factor V^2/4R.
    got it?
  3. mlkcampion
    Nov 16, 2006
    59
    Cheers recca
    I see what your doing alright, though for some reason i end up with
    4R^2 under the line!!
    Mike
  4. recca02
    Apr 2, 2007
    1,211
    do not try to simplify the denominator,
    just cancel what'er term can be cancelled. do not mess with the brackets :p
