Maximum power transfer question
Discussion in 'Homework Help' started by electroboc, Nov 24, 2011.
  1. electroboc
    Nov 17, 2011
    Any body able to give me a hand with this question?
    A. The value of R and X that will result in maximum power to be transfered across terminals A and B?
    B. The value of Maximum power?
    can anyone give me any direction??
    Many thanks
  2. jimkeith
    Oct 26, 2011
    539
    99
    My guess is that if you isolate the load and determine the thevenin Zequiv in rectangular form, you will have the max transfer of power when R and X are equal to these values as L and C will series resonate.
    Happy Thanksgiving Day, if you live in the US
  3. t_n_k
    Mar 6, 2009
    5,448
    783
    Another perspective:
    The load would need to be the complex conjugate of Zequiv.
    So if Zequiv=A+jB then the required load for MPT would be Zload=A-jB.
  4. bountyhunter
    Sep 7, 2009
    2,498
    507
    I believe maximum power transfer always occurs when source impedance matches load impedance. That's why antennas use impedance matching transformers to match the 75 Ohm transmission line.
  5. Yako
    Nov 24, 2011
    245
    ^ Yeah that's right
    XL = XC = resonance / max amplitude
    Tuning for max amplitude.
  6. Yako
    Nov 24, 2011
    245
    XC = 1 / 2 pi (fc)
    I have forgotten XL equation.
  7. t_n_k
    Mar 6, 2009
    5,448
    783
    That's true when the load and source impedances are purely resistive.
    When there are complex reactive terms involved then the MPT occurs when you have complex conjugate matching between the source and load.
  8. electroboc
    Nov 17, 2011
    one question i have, i have removed the load and worked out the short circuit voltage and have 50 volts.
    when you work out the impedance i am struggling on whether just product over sum
    5x5 over 5+5 or do i need to incorporate the j10ohm as well due to the phase angle?
