maximum load current in zener diode
Discussion in 'Homework Help' started by Hafiz Rafeeq, Sep 7, 2015.
  1. Hafiz Rafeeq
    Sep 7, 2015
    in the circuit shown, find maximum load current
  2. bwilliams60
    Nov 18, 2012
    734
    94
    If this is homework, it should go under the homework tab. Have you made any attempt at doing this yourself? Perhaps some background would help.
  3. ericgibbs
    Jan 29, 2010
    2,581
    389
    hi Hafiz,
    You have shown a supply voltage of only 3.2 Volts, is this correct.?
    E
  4. Alec_t
    Sep 17, 2013
    5,966
    1,133
    What are the component values?
    Where is the load?
  5. PeterCoxSmith
    Member
    Feb 23, 2015
    148
    38
    in the circuit given the current is constant (3.2/(R1+RV1)) (until the battery runs down) and the zener diode will never turn on
    Roderick Young likes this.
  6. Hafiz Rafeeq
    Sep 7, 2015
  7. PeterCoxSmith
    Member
    Feb 23, 2015
    148
    38
    24V/RV1
  8. Hafiz Rafeeq
    Sep 7, 2015
    but i am looking for a specific numeric answer
  9. crutschow
    Mar 14, 2008
    13,473
    3,361
    You've been given enough information to calculate that.
  10. Hafiz Rafeeq
    Sep 7, 2015
    t
    the people who gave me the question at least think so..
  11. #12
    Nov 30, 2010
    16,664
    7,311
    I'm going to Tennessee. I don't know how far it is but I will be traveling at 65 miles per hour. How long will I have to drive at that speed. I want a specific numeric answer.
    absf likes this.
  12. ian field
    Distinguished Member
    Oct 27, 2012
    4,447
    791
    What was the number they came up with on The Hitch Hikers Guide to the Galaxy?
    #12 likes this.
  13. #12
    Nov 30, 2010
    16,664
    7,311
    Forty-two. :p
  14. Alec_t
    Sep 17, 2013
    5,966
    1,133
    42. (Sorry, I forgot we're not allowed to give answers to Homework questions :)).
    Edit: Pipped at the post by #12!
  15. PeterCoxSmith
    Member
    Feb 23, 2015
    148
    38
    then start putting in some numbers. You know you want 10mA through the zener so set the value of R1 with RV1 open circuit. Change value of RV1 and see how R1 must change to keep 10ma in the zener plus the current in RV1. Try a whole series of values for RV1, plot some graphs. Use Excel.
  16. DerStrom8
    Feb 20, 2011
    2,428
    1,329
    This forum is not here to do your homework for you. That's your job.
  17. WBahn
    Mar 31, 2012
    18,080
    4,917
    MOD NOTE: Moved from General Electronics Chat to Homework Help.
  18. bertus
    Administrator
    Apr 5, 2008
    15,797
    2,384
  19. WBahn
    Mar 31, 2012
    18,080
    4,917
    It depends on what specifications you make regarding the design.
    First, are you sure that the power rating on the zener is 600 W and not 600 mW?
    A common design approach for a circuit like this (at least in an academic setting) is to design the circuit so that the zener is operating at it's maximum current allowable when the load is at one of its extreme limits. What would that mean for this circuit?
  20. bwilliams60
    Nov 18, 2012
    734
    94
    I could have swore someone already said that. :p
