MAX7000s clock?
Discussion in 'General Electronics Chat' started by Konstabel, Feb 2, 2008.
  1. Konstabel
    Thread Starter Active Member
    Jan 31, 2008
    52
    Is it an absolute must to have a clock on the cpld? The code I am planning to implement is basically to give me extra I/O ports on my uP. I would like to drive 8 7-segment displays from my cpld, my uP would not be able to handle that amount of I/O pins.
  2. mrmeval
    Distinguished Member
    Jun 30, 2006
    833
  3. scubasteve_911
    Dec 27, 2007
    1,202
    That's a really good question! I am not sure, but I believe you do not require a clock. Perhaps, during configuration, if you are in a programming mode that requires the CPLD to source a clock, then obviously you will need them. Usually PROMs are master-serial/parallel devices.
    Steve
  4. nanovate
    May 7, 2007
    665
    If it is all combinatorial logic then you probably do not need one.
  5. SgtWookie
    Jul 17, 2007
    22,183
    1,728
  6. electronictech
    Apr 1, 2009
    35
    You do not need a clock.
    Modern CPLD's have flash configuration memory, so once you download the design, the CPLD will operate as programmed as soon as power is applied.
    CPLD's are assignable logic devices, you can embed just about any logic design into it, and assign pins to specific points.........basically you can build the PCB first, then program the device to work with it.
