hai all,
I have system that use PC and uC. 1st PC control the system using VB then send data to uC using max232to print out some note at LCD screen. The main problem is max232 only cover short distance. I have heard people said to use max485 to get more distance in data sending, but the problem is, it difficult to understand the circuit that i attached. Beside that i also want to know if max232 and max485 will interface together to make far connection. If possible could someone help me with full circuit connection between PC and uC. Thanks.......
