MAX333A(analog and digital parts)
Discussion in 'General Electronics Chat' started by Crowbar, Dec 19, 2006.
  1. Crowbar
    Thread Starter Active Member
    Dec 19, 2006
    32
    Hi. I have a question about MAX333A analog switch: It will be used to switch on-off HPF filters. My circuit have separated analog and digital grounds, connected in a single point(star)- max333a have only one GND pin(no separated agnd dgdg)- how this GND must be connected to analog and digital grounds of my circuit(should i connect only dgnd to MAX333A GND or agnd must be connected also)?
    Regards, Konstantin.
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    Looking over the spec sheet, the ground pin is used as a reference for the logic signal, so connect to the digital ground.
  3. Crowbar
    Dec 19, 2006
    32
    Howhever, this anlog switch is using transistors of course- as i remember the simple transistor switch has common emitter which is connected to gnd; to be honest- I am dissapointed looking on MAX333(sorry, where at pdf Have you seen that gnd is used as a digital reference?)
    Best Regards.
  4. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    The analog switch uses FET's as switching elements. I've used analog switches before - the logic signal needs the ground. The limits of the switch's signal capability are set by the V+ and V- terminals.
  5. Crowbar
    Dec 19, 2006
    32
    Ok, thanks for your expirience, cause i've never used analog switches before.
  6. Crowbar
    Dec 19, 2006
    32
    How can I calculate voltage noise which is given by MAX333?
  7. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    Look over the spec sheet for the device. The information will be there.
  8. Crowbar
    Dec 19, 2006
    32
    There we have leakage current and on resistance only wich affects noise, i suppose, but no directly noise specs..
