MAX3316 Equivalent
khanna_gunjan
Joined Jan 29, 2006
8
Hello Freinds,
I am looking for a chip, which is pin compatible with MAX3316 and is also low voltage driven (2.5V or 3V),
Please Suggest.. Thanks in advance
Gunjan
Papabravo
Joined Feb 24, 2006
21,228
Originally posted by khanna_gunjan@Apr 20 2006, 07:44 AM
Hello Freinds,
Gunjan
[post=16354]Quoted post[/post]​
Just to be clear, the MAX3316 is NOT a UART, it is a transceiver with two tansmitters and two receivers. That said, I don't think the world is overflowing with second sources for proprietary chips. If you want the function, you pay the freight.
I could be wrong though, there might be one out there. How much is the answer worth in terms of your time and resources?
windoze killa
Joined Feb 23, 2006
605
[post=16363]Quoted post[/post]​
Also why do you want a different one? I feel Maxim are the leaders in this tech so their chip should be exactly whats needed.
Papabravo
Joined Feb 24, 2006
21,228
[post=16371]Quoted post[/post]​
He wants an alternative because Maxim chips are either unavailable or too expensive. I agree with you WK; who has time to look for alternatives when the solution is right in front of you. People are expensive, silicon is cheap.
windoze killa
Joined Feb 23, 2006
605
[post=16374]Quoted post[/post]​
How do you know that????? Nothing about that in his original post.
Papabravo
Joined Feb 24, 2006
21,228
[post=16376]Quoted post[/post]​
Call it an educated guess. I could be wrong though.
khanna_gunjan
Joined Jan 29, 2006
8
[post=16379]Quoted post[/post]​
well i am looking for an alternative only because it is not easily availbale and i needed the chip urgently for the develooment.. anyways thanks i have found an alternate part with Texas Instrument (SN75C3232DBR)
