Max232 to convert non-standard rs232 signal to TTL?
Discussion in 'General Electronics Chat' started by jeff77789, Apr 2, 2013.
  1. jeff77789
    Feb 22, 2013
    18
    Today, 06:58 PM #1
    I actually have a MAX3232 that i bought from here:
    https://www.sparkfun.com/products/589
    now i am also using a maxbotix MB1020 sensor in which it gives out an RS232 serial signal from the tx pin:
    When the *BW is open or held low, the TX output delivers
    asynchronous serial with an RS232 format, except voltages are 0-Vcc.
    The output is an ASCII capital “R”, followed by three ASCII character
    digits representing the range in inches up to a maximum of 255,
    followed by a carriage return (ASCII 13). The baud rate is 9600, 8
    bits, no parity, with one stop bit. Although the voltage of 0-Vcc is
    outside the RS232 standard, most RS232 devices have sufficient
    margin to read 0-Vcc serial data. If standard voltage level RS232 is
    desired, invert, and connect an RS232 converter such as a MAX232.
    When BW pin is held high the TX output sends a single pulse, suitable
    for low noise chaining. (no serial data).
    http://www.maxbotix.com/documents/MB1020_Datasheet.pdf
    my understanding is that the signal is exactly inverted or opposite of TTL with the exception of voltage levels. basically 0v - 5v RS232
    so if i were to set up the MAX3232 to convert the RS232 to a TTL signal, what would i receive and would this be compatible with an arduino in the sense that it is still 0v - 5v?
    side question: what is a good thing to solder the MAX3232 onto if i dont have a PCB ...?
  2. MrChips
    Oct 2, 2009
    12,635
    3,453
    Just invert the signal with a common emitter NPN transistor circuit and feed this into the Arduino.
