MAX1747 circuit
Discussion in 'General Electronics Chat' started by Oussama Zaidi, May 5, 2016.
  1. Oussama Zaidi
    Mar 1, 2016
    53
    Hi
    In MAX1747 datasheet, there is the montage in the picture above, everything is clear with the values and everything, only those diodes I don't understand what is their role, also they put them without any information about them in the datasheet so I don't know how to choose them, anyone has an idea about that?
    Datasheet: https://datasheets.maximintegrated.com/en/ds/MAX1747.pdf
  2. crutschow
    Mar 14, 2008
    13,523
    3,392
    You just didn't read far enough. ;)
    They are mentioned on page 12 of the data sheet (Rectifier Diodes).
  3. Oussama Zaidi
    Mar 1, 2016
    53
    Thank you :)
  4. jjw
    Member
    Dec 24, 2013
    175
    32
    The diodes with the capacitors form a voltage multiplier ( 3 × the input voltage ) The voltage is controlled with the feedback circuits inside the IC.
