Thank you for all the help, especially to you two.
I'm not sure if it was the change from electrolytic to ceramic what solved the problem, or if it was separating both supplies with the resistor and adding individual caps to each. I suspect it was the later, because I believe I tried the ceramics instead of electrolytics at the very beginning without solving the problem.
I've been running a whole battery of tests, and it works far better than I have never expected; not a single glitch or issue, unlike the other function generator I did last year, which is practically useless due to all the problems it has.
But -and it's not my intention to re-open this discussion- in one of the tests I noticed that even with the dual bench power supply, under a load from 1kΩ the resulting wave begins to experience a drop in amplitude (an issue that we discussed before). I wasn't expecting this to happen, since the power supply is good for 7.5A in the +5V rail and 300 mA in the -5V rail; which is well within the maximum power limits I calculated through the datasheets. But even then, the amplitude begins to drop with a 1kΩ load, is down to 80% with a 700Ω load, and to 60% with a 100Ω load.
I decided to do the same tests with a new recalculated shunt regulator with the zeners; I built another test circuit, and power it up with it. I got the exact same results as with the dual bench power supply! The exact same drops in amplitude with the exact same loads.
So I was thinking: if I'm going to get the exact same results whether I use the bench supply, the switching supply, or the zeners supply, what am I going to gain by ordering the components and rebuilding it again; especially when this PCB is already traced for the zeners?
I understand the reasons you gave for a power supply that could supply the maximum power needed, and why the zeners would never achieve this -especially when I'm measuring the power consumption with a multimeter, which is giving me the wrong reading- and I totally agree with you, but at this point I don't see the practical benefits, or any improvements I would get by changing the power supply to the switching one... unless I'm missing something here.
Anyway, this is the picture I promised of what the final project looks like:
