max usb signal frequency
Discussion in 'Embedded Systems and Microcontrollers' started by ranch vermin, Sep 20, 2015.
  1. ranch vermin
    May 20, 2015
    85
    I was just needing to know whats the peak frequency down a usb wire?
    Just guessing... 3ghz?
  2. shteii01
    Feb 19, 2010
    3,500
    511
    Depends on bitrate.
    1.5 Mbits/s is the lowest.
    10000 Mbits/s is the highest.
  3. Papabravo
    Feb 24, 2006
    10,340
    1,850
  4. MaxHeadRoom
    Jul 18, 2013
    10,839
    2,515
    USB3 is rated now for up to 5gbs (640MBps) but has been found in practice to be quite a bit lower, but still quite a bit higher than USB2.
    Max.
  5. ranch vermin
    May 20, 2015
    85
    I see - its not the "frequency" its the bitrate, thankyou.
