max symmetrical swing
Discussion in 'General Electronics Chat' started by automagp68, Dec 10, 2015.
  1. automagp68
    Nov 13, 2011
    81
    Can someone help me understand how to get an AC swing from a BJT NPN
    This is just something i want to practice on my own. I am familiar with the operation
    Im choosing an NPN just for simplification. Say a 15-20v supply either bipolar or single ended
    Gain not important. I just want to see the swing.
    Say 6v PP swing so 3 volt peak swing.
  2. Jony130
    Feb 17, 2009
    3,991
    1,115
  3. MikeML
    Oct 2, 2009
    5,451
    1,066
    (I see Jony beat me to it)
    Common-Emitter NPN transistor amplifer. Bias voltage is 3Vdc. Input is +-50mV, riding on the bias. Emitter is grounded for AC signal. Gain makes ~6Vpp at collector, but it rides on the quiescent output voltage of ~9Vdc. Use a DC blocking capacitor to make a symmetric output swing (around ground) of +-3V.
  4. automagp68
    Nov 13, 2011
    81
    ok thanks for the help
    So i understand the swing a little bit better
    What I'm fooling with is a simple power BJT
    I got the swing i wanted, now I'm trying to get it to drive an 8 ohm load
    This is just a sim and will never be built so practicality is not a concern
    I built a simple little circuit and got the swing i wanted but when i attach my 8 ohm load i loose my swing.
    The load is capacitivley coupled from the collector
    I designed for a 3v peak swing or 6v pp
    with an 8 ohm load i biased the bjt for about 265 mA
  5. MikeML
    Oct 2, 2009
    5,451
    1,066
    If your amplifier is a small-signal NPN with a collector load resistor of a few KΩ, then the amplifier can only drive a load which at least as high as the collector resistor, meaning that an 8Ω will just totally overload the whimpy amplifier.
    If you had an old "transistor radio output transformer", with an input impedance of like 500Ω, and an output impedance of 8Ω, you could make it work.
    Direct-drive of an 8Ω speaker takes a much different type of amplifier...
  6. automagp68
    Nov 13, 2011
    81
    I thought of a transformer also
    so just for quick and dirty practices and because i don't know anything about push pull design or power amps
    Just to get a quick simulation working what do u think my best bet is?
