max power transfer, multisim (yes i said multisim!) problem
ninjaman
Joined May 18, 2013
341
hello all
I have a problem:
V thev= 22
R thev= 1500
Rload = ? (thought im guessing 1500)
I got these values
Rthev Rload total
e 10.9995 10.9995 22
I 7.333mA 7.333mA 7.333mA
r 1500 1500 3000
p 80.65mW 80.65mW 161.318mW
I tried this on multisim and found that I was getting 80.65mW but when I used a 1500 ohm load I got zero W, nothing at all. if I changed the load to 1505 I got 80.66mW, 1499 I got 80.66mW. but nothing with 1500. I have to do a screen print to prove my maths but cant get the power to show???
any help would be great
also, my method
I removed source,
added two resistors,
voltage over total resistance equals current,
current times Rthev equals voltage drop across Rthev
current times Rload equals voltage drop across Rload
then current squared times Rthev for power, and
then current squared times Rload for power
thanks
simon
WBahn
Joined Mar 31, 2012
30,045
Why are you guessing about what load impedance will result in maximum power transfer. The whole point of learning about this is to KNOW that.
I'm confused. You provide a table of the results you got and it includes 80.65 mW for a 1500 Ω load, but you then say that you got 0 W for a 1500 Ω load. Which is it.
WBahn
Joined Mar 31, 2012
30,045
Because the OP said "Rload = ? (thought im guessing 1500)"
Maybe I'm misreading things, but I interpreted this as being the question asked what is Rload need to be equal to to achieve max power transfer and the OP is guessing that it is 1500 Ω.
ninjaman
Joined May 18, 2013
341
hello WBahn
sorry I didn't write it correctly. I used a 1500 ohm resistor as the load and got nothing on the power meter, then I changed the resistance by 5 ohms to 1505 ohms. this gave me a value. so I think its something that multisim didn't like. this is the problem im having. I have to do a print screen showing the value as proof.
the question was does anyone know what I can do to get the power meter working with 1500 ohm exactly.
thanks
simon
ninjaman
Joined May 18, 2013
341
Show your screen shot. That might help us.
hello JoeJester
in the one on the right I changed the load resistance to 1501 ohms and can measure the power output, but I get nothing with 1500 ohm resistor.
any help!!!
thanks
simon
WBahn
Joined Mar 31, 2012
30,045
Can you display what it is seeing for the voltage and current values separately?
I agree that something hinky appears to be going on.
What happens if you fix the load resistor at 1500 Ω and make slight changes up and down to the other components? What if you cut the values of all the components in half or double them?
ninjaman
Joined May 18, 2013
341
here with half value resistor twice the current.
I don't think multisim likes it when I do this.
JoeJester
Joined Apr 26, 2005
4,390
I know it looks like the connection is fine .... and it should work, unless ... can you move R2 and make sure that line connected to the top of R2 moves with your relocation. That is the ONLY way I can see you would get such an indication IF the connected line doesn't move.
I don't use multisim, but, if you ran a dc analysis stepping the resistance of R2 from o to 3k ohms you would see something like the chart below. The same could be seen if you did the same thing in excel spreadsheet.
WBahn
Joined Mar 31, 2012
30,045
What happens if you connect the wattmeter to the other resistor (when they are both evenly matched)?
Have you tried opening up a brand new schematic and doing it from scratch to see if you get the same weird results?
ninjaman
Joined May 18, 2013
341
hello WBahn
I have tried it a few ways and still get the 0 Watts. I did however try the wattmeter and a separate volt meter across the load and that worked. which is strange. I think I will do that for my result. as long as I can show the correct value.
thanks for your help fellas!
simon
