Max Power Proof
Discussion in 'Homework Help' started by ihaveaquestion, May 5, 2009.
  1. ihaveaquestion
    Thread Starter Active Member
    May 1, 2009
    314
    http://img140.imageshack.us/img140/3572/scan0028.jpg
    a) the only proof I can come up with is that for RS = 0, RL would have max power put into it because there would be no voltage drop across RS since it doesn't exist, so since p=vi, the max power (source) would be going into RL.
    b) I'm not sure
    c) I'm not sure
    Doing some analysis on the circuit I know that:
    VL = Vi*(RL/RS+RL)
    VS = Vi*(RS/RS+RL)
    I = Vi/(RS+RL)
    We did this problem before.. you have to get a function of something and take the derivative to maximize the function...
  2. steveb
    Jul 3, 2008
    2,433
    469
    Part A is easy since Rs=0 results in the greatest current and greatest voltage across RL. Since P=VI, power is clearly maximized.
    Part B is the tricky one. The usual approach is to write the power in RL as a function of RL and other known quantities. Then take the first derivative of power with respect to RL. Set this to zero and solve for RL. It will be clear that RL=Rs maximizes power.
    Part C is easy once you prove B because the resistors are equal in value and the have equal current flowing in them. P=I^2*R, hence power is the same in both resistors.
  3. ihaveaquestion
    May 1, 2009
    314
    Ok I'll try that right now:
    In the meantime I have a quick question about current divider
    http://img134.imageshack.us/img134/4711/73592586.jpg
    1) Are those two circuits equivalent?
    I think they are... if I moved the R2 resistor over to the left side, they wouldn't be equivalent because I'm not allowed to do that right? I can only rearrage R1 like that...
    2) Are these expressions correct for both circuits?
    i1 = I*(R2/R1+R2)
    i2 = I*(R1/R1+R2)
  4. ihaveaquestion
    May 1, 2009
    314
  5. steveb
    Jul 3, 2008
    2,433
    469
  6. steveb
    Jul 3, 2008
    2,433
    469
    For #2 above, the formula look correct.
    For #1 above, I think there is a mistake. You can move R1 to the other side (as you showed in the figure), but you can also move R2 to the other side. Why do you say it's not allowed to move R2 and but R1 is OK? This would seem to violate symmetry since both resistors are connected the same in terms of node connections. In general, the physical location of components will not matter for circuits, only the nodal connections are important. (Note: Every rule has exceptions, but you are nowhere near a situation with transmission line effects, electromagnetic radiation or Faraday Law inductive coupling effects)
  7. ihaveaquestion
    May 1, 2009
    314
    Ahh I see... I understand, thanks
