Included is my schematic.
Just a few questions about this setup. I would like to use the Internal Pullups on PORTB. I have just a small hobby box to put it in and really have no room for external resistors. Does this program look right for the schematic. The program seems to work on a PIC simulator (PIC simulator 1.3), but doesn't seem to work in the real world
I read from this forum that I must have MCLR enabled to use the weak pullups on PORTB. So that is why that is so in the configuration line for the chip.
The LCD is "wired: correctly and initializes and displays text so I'm pretty sure the problem is the program side of things. Can someone please look at this and critique it. I appreciate any help anyone can provide. Here is the code for the Main.c
Rich (BB code):
//This program controls a Matrix Switch. The Switch consists of 3 columns and 4 rows.
//Whenever a button is pushed, that button is displayed on an LCD Display.
//PIC16F886 Microcontroller from Microchip is being used.
#include <htc.h>
#include "lcd.h"
#define KEY_PORT PORTB //Defining PORTB as KEY_PORT
#define KEY_SET(bits) KEY_PORT |= (bits) //Defining KEY_SET as
#define KEY_CLR KEY_PORT &=~ (bits) //Defining Key_CLR as KEY_PORT = KEY_PORT &~ (bits)
#define KEY_FLP(bits) KEY_PORT ^= (bits) //Defining KEY_FLP as KEY_PORT = KEY_PORT ^ (bits)
#define KEY_IN(bits) TRISB |= (bits) //Defining KEY_IN as TRISB = TRISB | (bits)
#define KEY_OUT(bits) TRISB &=~ (bits) //Defining KEY_OUT as TRISB = TRISB &~ (bits)
#define KEY_COL 0b10000011 //Defining KEY_COL as high,low,low,low,low,low,high,high
#define KEY_ROW 0b01111000 //Defining KYE_ROW as low,high,high,high,high,low,low,low
#define DelayS(T) {unsigned char i; for (i = 0; i < T * 10; i++) __delay_ms(100);} //Delay Macro
#define _XTAL_FREQ 4000000 //Needs to be set for __delay_ms
/////CONFIGURATION FUSE//////////////////////////////////////////////////////////////////////////////////////////////////////////
//Master Clear Reset enabled & Internal RC No Clock & Watchdog Timer Disable & Power Up Timer On & Brown Out Reset Disabled &
// Low Voltage Porgramming Disabled & Code Unprotect
__CONFIG (MCLREN & INTIO & WDTDIS & PWRTEN & BORDIS & LVPDIS & UNPROTECT);
unsigned char key_read(unsigned char in_bits, unsigned char out_bits)
KEY_IN(in_bits);
KEY_SET(out_bits);
KEY_OUT(out_bits);
return KEY_PORT & in_bits;
unsigned char key_detect(void)
unsigned char tmp1, tmp2;
tmp2 = key_read(KEY_ROW, KEY_COL);
tmp1 = key_read(KEY_COL, KEY_ROW);
return tmp1 | tmp2;
main ()
PORTA = 0x00; //PORTA is cleared and set low
PORTB = 0x00; //PORTB is cleared and set low
PORTC = 0x00; //PORTA is cleared and set low
TRISA = 0x00; //Set PORTA to outputs
TRISB = 0xFF; //Set PORTB to inputs
TRISC = 0x00; //Set PORTC to outputs
RBPU = 0; //Internal PORTB Pullups enabled
ANSEL = 0; //Initialize A/D Ports off
ANSELH = 0; //Initialize ........
CM1CON0 = 0; //Initialize Comparator 1 off
CM2CON0 = 0; //Initialize Comparator 2 off
OPTION = 0b01010101; //OPTION REG
//xbxxxxx101 1:64
//xbxxxx0xxx Prescaler set to Timer0
//xbxxx1xxxx (T0SE) set to Increment on high-to-low transition on T0CKI pin
//xbxx0xxxxx (T0CS) Internal instruction cycle clock
//xbx1xxxxxx (INTEDG) Interrupt on rising edge of INT pin
//xb0xxxxxxx (RBPU) PORTB pull-ups are enabled by individual PORT latch values
lcd_init(); //LCD Display is Initialized...See if LCD.C file
/////IGNORE THIS -- ONLY A TEST//////////////////////////////////////////////////////////////////////////////////////////////////
//Only a test to see if LCD is Initialized and Display Text
//while (1 == 1)
// lcd_clear();
// lcd_goto(0);
// lcd_puts("Hello World");
// __delay_ms(150);
// lcd_goto(40);
// lcd_puts("LCD Iniatlized");
// __delay_ms(150);
//} //Everything After this would be commented out
char key; //Creating a local Variable called "key" to hold value of key is pressed
while (key_detect() == 1) //Loops When Key is Pressed
continue;
key = key_detect(); //Referring to key_detect() function. Returns key pressed.
switch (key) //Switch Statement for "key"
case 0b00100001: //Column 1 Row 4--Switch 12
lcd_goto(0);
lcd_puts("Switch 1");
//DelayS(1);
lcd_clear();
break;
case 0b01000001: //Column 1 Row 3--Switch 11
lcd_goto(0);
lcd_puts("Switch 2");
//DelayS(1);
lcd_clear();
break;
case 0b00010001: //Column 1 Row 2--Switch 10
lcd_goto(0);
lcd_puts("Switch 3");
//DelayS(1);
lcd_clear();
break;
case 0b00001001: //Column 1 Row 1--Switch 9
lcd_goto(0);
lcd_puts("Switch 4");
//DelayS(1);
lcd_clear();
break;
case 0b00100010: //Column 2 Row 4--Switch 8
lcd_goto(0);
lcd_puts("Switch 5");
//DelayS(1);
lcd_clear();
break;
case 0b01000010: //Column 2 Row 3--Switch 7
lcd_goto(0);
lcd_puts("Switch 6");
//DelayS(1);
lcd_clear();
break;
case 0b00010010: //Column 2 Row 2--Switch 6
lcd_goto(0);
lcd_puts("Switch 7");
//DelayS(1);
lcd_clear();
break;
case 0b00001010: //Column 2 Row 1--Switch 5
lcd_goto(0);
lcd_puts("Switch 8");
//DelayS(1);
lcd_clear();
break;
case 0b10100000: //Column 3 Row 4--Switch 4
lcd_goto(0);
lcd_puts("Switch 9");
//DelayS(1);
lcd_clear();
break;
case 0b11000000: //Column 3 Row 3--Switch 3
lcd_goto(0);
lcd_puts("Switch 10");
//DelayS(1);
lcd_clear();
break;
case 0b10010000: //Column 3 Row 2--Switch 2
lcd_goto(0);
lcd_puts("Switch 11");
//DelayS(1);
lcd_clear();
break;
case 0b10001000: //Column 3 Row 1--Switch 1
lcd_goto(0);
lcd_puts("Switch 12");
//DelayS(1);
lcd_clear();
break;
