matrix problem
Discussion in 'Homework Help' started by ees1, Oct 16, 2008.
  1. ees1
    Thread Starter Active Member
    Jan 7, 2008
    37
    One of my lecture notes showing a 3x3 matrix, let's name this matrix Y.
    I am confused about the result Y^-1.
    I am trying to find some study material for relating to Y^-1, and I couldn't find any useful information(actually I still don't know how professor got his answer)
    I guess the material I studied wasn't right. Could anyone can provide the searching key words for learning this related subject?
  2. Papabravo
    Feb 24, 2006
    10,340
    1,850
    Sure, Y^-1 is the inverse of Y. When you multiply the two matricies together you get the Identity matrix
    Code ( (Unknown Language)):
    1.
    2. Y*Y^-1 = I = [ 1 0 0 ; 0 1 0 ; 0 0 1]
    3.
    Many software packages like Matlab, Scilab, and R will give you the inverse of a 3 x 3 matrix in the twinkling of an eye. I've heard tell that inverting one by hand is possible by using minors and cofactors but I haven't done it recently. Inverting a 4 x 4 or larger is definitely not -- you'll excuse the expression -- a hand job.
  3. ees1
    Jan 7, 2008
    37
    thank you. I think I will use the TI caculator instead.:)
  4. scubasteve_911
    Dec 27, 2007
    1,202
  5. Dave
    Retired Moderator
    Nov 17, 2003
    6,960
    145
    PB, I recall the manual approach was quite laborious. You are right to suggest numerical packages like Matlab, which is expensive, so look at one of the matrix-based (free) alternatives: http://forum.allaboutcircuits.com/blog.php?b=65
    Dave
  6. Papabravo
    Feb 24, 2006
    10,340
    1,850
  7. Dave
    Retired Moderator
    Nov 17, 2003
    6,960
    145
    Added to the list. Thanks Papabravo.
    Dave
  8. hgmjr
    Jan 28, 2005
    9,030
    214
    Don't overlook the fact that Microsoft EXCEL has a matrix function that can be used to perform matrix manipulation.
    hgmjr
