Matlab
Discussion in 'Programmer's Corner' started by Cerkit, Jan 10, 2010.
  1. Cerkit
    Thread Starter Active Member
    Jan 4, 2009
    275
    Hi. Can someone explain to me why I am getting a series of dots in a straight line when i try to plot this in matlab
    E=0:0.01:70;
    X=sqrt((75-E)/E);
    plot(E,X)
  2. steveb
    Jul 3, 2008
    2,433
    469
    Try the following:
    Code ( (Unknown Language)):
    1.
    2.
    3. E=0:0.01:70;
    4. X=sqrt((75-E)./E);
    5. plot(E,X)
    6.
    7.
    The use of the dot (.) before multiply and division allows the array values to be used in proper order as you intended. This notation is necessary because Matlab allows multiplication and division (inversion) of matrices.
  3. Cerkit
    Jan 4, 2009
    275
    Thanks that did it. Also if you have a look at
    http://en.wikibooks.org/wiki/Materials_in_Electronics/Confined_Particles/1D_Finite_Wells
    where they have a graph closer to the end of the page they manage to plot
    Y=tan(((sqrt(2*me*E))/(hbar))*L);
    how is it that when I plot this on matlab with similar method to plotting as for X I get something that looks like noise rather than the tan expected. The constants I use are
    hbar=6.582e-016
    me=9.11e-31
    L=0.2*10^-9
    what am I doing wrong?
  4. steveb
    Jul 3, 2008
    2,433
    469
    When I use the following code, I don't get noise.
    1.
    2. [FONT=Courier New][SIZE=2][FONT=Courier New][SIZE=2]hbar=6.582e-016[/SIZE][/FONT]
    3. [SIZE=2][FONT=Courier New]me=9.11e-31[/FONT][/SIZE]
    4. [SIZE=2][FONT=Courier New]L=0.2*10^-9[/FONT][/SIZE]
    5. [SIZE=2][FONT=Courier New]E=0:0.01:70;[/FONT][/SIZE]
    6. [SIZE=2][FONT=Courier New]Y=tan(((sqrt(2*me.*E))/(hbar))*L);[/FONT][/SIZE]
    7. [SIZE=2][FONT=Courier New]plot(E,Y)[/FONT][/SIZE]
    8. [/SIZE][/FONT]
    However, I think you need to check your units. The range of values does not seem realistic. I think the issue may stem from using E in eV and me in kg.
    Note that sqrt(me*E)/hbar is not going give you the correct values, unless E is in J and me is in kg, with hbar in units of Js. I mentioned this potential "units" problem in the other post. It's usually safer to stick with SI units consistently.
