Matlab Stimulation: problem connecting voltage measurement
Discussion in 'Programmer's Corner' started by TYH, Nov 2, 2014.
  1. TYH
    Nov 2, 2014
    Hi all,
    I am doing my FYP and came across some problem when I was doing the stimulation. There is some problem regarding the connection of the voltage measurement to other components e.g resistor, which i cant seem to connect at all. I did google for ways to solve but apparently I still cant find a solution to it.
    Anybody out there who is able to solve this problem? I would really appreciate it. Thanks in advance!
  2. shteii01
    Feb 19, 2010
    3,500
    511
    What is the problem?
  3. TYH
    Nov 2, 2014
    The voltage measurement cant be connected to the other components.
  4. shteii01
    Feb 19, 2010
    3,500
    511
    Are you trying to measure voltage from the top of the resistor to the ground (across resistor and Vce)? Or are you trying to measure just the resistor?
  5. TYH
    Nov 2, 2014
    I want to measure the voltage of the resistor to the ground.
